[GRASS-dev] Re: [GRASS GIS] #787: v.in.db: add v.in.ogr-like "-t" option
Michael Barton michael.barton at asu.edu
Wed Jan 13 10:18:35 EST 2010
On Jan 13, 2010, at 3:41 AM, grass-dev-request at lists.osgeo.org wrote:
> Message: 8
> Date: Wed, 13 Jan 2010 10:06:37 -0000
> From: "GRASS GIS" <trac at osgeo.org>
> Subject: [GRASS-dev] Re: [GRASS GIS] #787: v.in.db: add v.in.ogr-like
>        "-t"    option
> To: undisclosed-recipients:;
> Message-ID: <055.d16c0a53f64b6dcb3f7115fa194af191 at osgeo.org>
> Content-Type: text/plain; charset="utf-8"
>  Reporter:  grasslandtom  |       Owner:  grass-dev at lists.osgeo.org
>      Type:  enhancement   |      Status:  closed
>  Priority:  normal        |   Milestone:  6.4.0
> Component:  Vector        |     Version:  unspecified
> Resolution:  invalid       |    Keywords:  v.in.db
>  Platform:  Unspecified   |         Cpu:  Unspecified
> Changes (by grasslandtom):
>  * status:  new => closed
>  * resolution:  => invalid
> Comment:
> Oops! I see, I should have asked on the mailinglist before filing this.
> Nevertheless: what I meant was something like
> #import vector from table without copying the table:
> v.in.db -t sometable x=x_col y=y_col cat=id_col out=somevector
> # connect to original table
> v.db.connect somevector table=sometable key=id_col
> But this could be mimicked by
> db.select sometable sql='select x_col,y_col,id_col from sometable' |
> v.in.ascii -t cat=3 out=somevector
> Thus I set this to resolved as invalid.
> Thanks for the hint with the pipe! Sorry for being to quick asking here.
> Tom
All well and good for *nix OS's, but Windows doesn't have a pipe like this.
Michael
