[GRASS-dev] [GRASS GIS] #869: Compile libs with -fexception
GRASS GIS trac at osgeo.org
Wed Jan 13 10:51:54 EST 2010
 Reporter:  rblazek    |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect     |      Status:  new
 Priority:  normal     |   Milestone:  6.5.0
Component:  Compiling  |     Version:  unspecified
 Keywords:             |    Platform:  Unspecified
      Cpu:  All        |
 I know, I want probably too much. Would it be possible to compile GRASS
 libraries (at least core libs gis, vect, ...) with -fexception by default?
 The problem is, that for example QGIS, sets error routine which throws an
 exception, everything works (even on Windows) but only if GRASS libs are
 compiled with -fexception. If -fexception flag is not used, the exception
 is thrown, but cannot be caught in QGIS and program is terminated.
 QGIS ticket http://trac.osgeo.org/qgis/ticket/1878
Ticket URL: <http://trac.osgeo.org/grass/ticket/869>
