[GRASS-dev] Re: [GRASS GIS] #869: Compile libs with -fexception
trac at osgeo.org
Wed Jan 13 18:07:08 EST 2010
Reporter: rblazek | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: closed
Priority: normal | Milestone: 6.5.0
Component: Compiling | Version: unspecified
Resolution: worksforme | Keywords:
Platform: Unspecified | Cpu: All
Old description:
> I know, I want probably too much. Would it be possible to compile GRASS
> libraries (at least core libs gis, vect, ...) with -fexception by
> default?
> The problem is, that for example QGIS, sets error routine which throws an
> exception, everything works (even on Windows) but only if GRASS libs are
> compiled with -fexception. If -fexception flag is not used, the exception
> is thrown, but cannot be caught in QGIS and program is terminated.
> QGIS ticket http://trac.osgeo.org/qgis/ticket/1878
New description:
libraries (at least core libs gis, vect, ...) with -fexception by default?
Comment (by neteler):
Replying to [ticket:869 rblazek]:
I have recompiled with -fexceptions (note the s)
# using something like this:
CFLAGS="-fexceptions" ./configure ...
and did not encounter any problems in GRASS 6.4.
Radim, where do you want to see -fexceptions be used?
Markus
Ticket URL: <http://trac.osgeo.org/grass/ticket/869#comment:5>
