[GRASS-dev] Re: [GRASS GIS] #863: set_env/unset_env should release memory
GRASS GIS trac at osgeo.org
Wed Jan 13 18:09:20 EST 2010
  Reporter:  rblazek      |       Owner:  grass-dev at lists.osgeo.org
      Type:  enhancement  |      Status:  new
  Priority:  normal       |   Milestone:  6.5.0
 Component:  libgis       |     Version:  svn-trunk
Resolution:               |    Keywords:
  Platform:  All          |         Cpu:  Unspecified
Comment (by glynn):
 Replying to [comment:5 rblazek]:
 > Do you think that a patch adding possibility to create more environments
 and switching between them using environment id/index would be accepted?
 That seems reasonable.
Ticket URL: <http://trac.osgeo.org/grass/ticket/863#comment:6>
