[GRASS-dev] Re: [GRASS GIS] #869: Compile libs with -fexception
trac at osgeo.org
Thu Jan 14 07:27:50 EST 2010
Reporter: rblazek | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: closed
Priority: normal | Milestone: 6.5.0
Component: Compiling | Version: unspecified
Resolution: worksforme | Keywords:
Platform: Unspecified | Cpu: All
Comment (by rblazek):
Replying to [comment:5 neteler]:
> Radim, where do you want to see -fexceptions be used?
In Lib.make? As Glynn pointed out, a test must be done if it is supported
by compiler.
BUT! You don't want to see Glynn's "dead body", I believe!
Ticket URL: <http://trac.osgeo.org/grass/ticket/869#comment:7>
