[GRASS-dev] Re: [GRASS GIS] #869: Compile libs with -fexception
Radim Blazek
radim.blazek at gmail.com
Thu Jan 14 11:16:02 EST 2010
Thanks for the suggestion. The title of
http://trac.osgeo.org/qgis/ticket/1878 is however "remove
setjmp/longjmp in grass plugin&provider and use exceptions instead" so
the intention was to remove setjmp/longjmp.
I don't know exactly if there were problems with setjmp/longjmp or it
was just attempt to improve the code. Using exceptions is certainly
better.
Radim
On Thu, Jan 14, 2010 at 4:59 PM, Soeren Gebbert
<soerengebbert at googlemail.com> wrote:
> I use in vtk.grass-bridge (C++ -VTK GRASS wrapper) a different approach.
> http://code.google.com/p/vtk-grass-bridge/
> Replacing the G_fatal_error() function and using the setjmp/longjmp
> construct allows you to catch all errors from grass, inclusively stack
> restoration. Glynn made this suggestion. :)
> This function replace G_fatal_error(), to set with
> G_set_error_routine(vgb_error_handler);:
> int vgb_error_handler(const char *msg, int fatal)
> if (fatal == 0)
> fprintf(stderr, "%s\n", msg);
> return 1;
> else
> fprintf(stderr, "\n############## Exceptiont called ###########\n");
> vgb_error_message = msg;
> longjmp(vgb_stack_buffer, 1);
> return 1;
> This is an example how to handle fatal errors (old example, still
> check for return value):
> if (!setjmp(vgb_stack_buffer))
> if (Rast_get_row(this->Map, this->RasterBuff, idx, this->MapType) < 0)
> error = 1;
> else
> this->InsertNextError(vgb_error_message);
> return NULL;
> Code examples from:
> http://code.google.com/p/vtk-grass-bridge/source/browse/trunk/Common/vtkGRASSDefines.h
> http://code.google.com/p/vtk-grass-bridge/source/browse/trunk/Common/vtkGRASSInit.cxx
> http://code.google.com/p/vtk-grass-bridge/source/browse/trunk/Raster/vtkGRASSRasterMapBase.cxx
> Soeren
> 2010/1/14 GRASS GIS <trac at osgeo.org>:
>> Reporter: rblazek | Owner: grass-dev at lists.osgeo.org
>> Type: defect | Status: closed
>> Priority: normal | Milestone: 6.5.0
>> Component: Compiling | Version: unspecified
>> Resolution: worksforme | Keywords:
>> Platform: Unspecified | Cpu: All
>> Comment (by rblazek):
>> Replying to [comment:8 hamish]:
>> > fwiw, wrt. -fexceptions, Francesco commented on the DebianGIS list:
>> This would be required for any C library linked by Qgis. This is out of
>> discussion.
>> Qgis has to manage correctly C libraries by providing wrappers to raise
>> execeptions
>> when C calls fail, else people will start asking that libc too supports
>> exceptions, soon or later...
>> Probably he does not know, that GRASS libraries can call exit(). No
>> wrapper can help in that situation AFAIK.
>> Ticket URL: <https://trac.osgeo.org/grass/ticket/869#comment:9>
>> GRASS GIS <http://grass.osgeo.org>
>> grass-dev mailing list
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
