[GRASS-dev] Re: [GRASS GIS] #869: Compile libs with -fexception
Martin Landa
landa.martin at gmail.com
Thu Jan 14 16:59:53 EST 2010
2010/1/14 Glynn Clements <glynn at gclements.plus.com>:
> Whichever approach is used, any code calling G_fatal_error() is
> entitled to assume that it won't be called again, so it doesn't need
> to perform clean-up.
OFT, some clean-up (at module level) would be reasonable, e.g. to
delete output raster/vector map if module fails.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
