[GRASS-dev] Re: [GRASS-SVN] r40421 - grass/branches/develbranch_6/gui/wxpython
Thu Jan 14 20:27:55 EST 2010
Martin Landa wrote:
> >>> Are you sure that the buttons are translated on your machine
> >>> without these changes?
> >> yes. Martin
> > As mentioned: not on Mandriva, not on XP.
> > Confirmed also on Windows7 from another colleague.. Due you have
> > unsubmitted changes?
> tested on Debian GNU/Linux and MS Windows XP with Czech locale.
> Buttons are localized without need to define label manually (tomorrow
> I will test on MS Windows Server 2008). I would incline to find out
> why it's not working on your system and to revert your changes.
The built-in translations should be in e.g.:
C:\Program Files\Python26\Lib\site-packages\wx-2.8-msw-unicode\wx\locale\ja\LC_MESSAGES\wxstd.mo
