[GRASS-dev] WinGrass-Installer - definition of the destination folder?
Sat Jan 16 18:48:00 EST 2010
Helmut Kudrnovsky wrote:
> at the moment in the NSIS-installer-script there are following options for the destinations-folders:
> [http://trac.osgeo.org/grass/browser/grass/branches/releasebranch_6_4/mswindows/GRASS-Installer.nsi#L28]
> Grass64-Release => RELEASE_GRASS_BASE "GRASS" => c:\GRASS
> Grass65-Dev     => DEV6_GRASS_BASE "GRASS-6-SVN" => c:\GRASS-6-SVN
> Grass7          => DEV7_GRASS_BASE"GRASS-7-SVN" => c:\GRASS-7-SVN
> but there is also the development-line of Grass64-svn, on which all
> the last WinGrass-Installers for testing are based.
> for a consistent way of a definition of the destination folder
> should there maybe the list be adapted to reflect all
> development-lines (and for the update-function of the installer)?
> maybe following options for the destination folder?
> Grass64-Release => c:\GRASS-64
> Grass64-Dev        => c:\GRASS-64-SVN
> Grass65-Dev        => c:\GRASS-65-SVN
> Grass7-Dev          => c:\GRASS-7-SVN
Grass64-Release => %ProgramFiles%\GRASS-64
Grass64-Dev     => %ProgramFiles%\GRASS-64-SVN
Grass65-Dev     => %ProgramFiles%\GRASS-65-SVN
Grass7-Dev      => %ProgramFiles%\GRASS-7-SVN
We *need* this to work. If GRASS can't handle being installed in
%ProgramFiles%, that's a blocker, IMHO.
Similarly if it can't handle spaces in GISDBASE.
