[GRASS-dev] Re: [GRASS GIS] #843: v.digit broken on new WinGrass release
GRASS GIS trac at osgeo.org
Sun Jan 17 07:52:49 EST 2010
  Reporter:  cnielsen      |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect        |      Status:  new
  Priority:  blocker       |   Milestone:  6.4.0
 Component:  Vector        |     Version:  unspecified
Resolution:                |    Keywords:  wingrass,v.digit
  Platform:  MSWindows XP  |         Cpu:  x86-64
Comment (by hamish):
 as far as I can tell in the latest wingrass installer v.digit(tcl) works
 so this is no longer critical, but I get an unexplained error message when
 I close it:
 Region restored to original extent.
 Building topology for vector map <(null)>...
 Registering promitives...
 Unable to read vector map
 I also notice an error in the output:
 DBMI-SQLite driver error:
 Error in sqlite3_prepare():
 near "where" syntax error
 Cannot update table
 I'm guessing that is because I hit submit (or didn't) in the Form when the
 only column in the table was cat? (???)
 the output from v.db.select looks as it should.
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/843#comment:24>
