[GRASS-dev] [GRASS GIS] #878: v.external not working on WinGrass
    trac at osgeo.org
    Sun Jan 17 18:33:12 EST 2010
 Reporter:  hellik                       |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect                       |      Status:  new
 Priority:  critical                     |   Milestone:  6.4.0
Component:  Vector                       |     Version:  svn-releasebranch64
 Keywords:  v.external, vector, windows  |    Platform:  MSWindows Vista
      Cpu:  x86-32                       |
 WinGrass r40456 on WinVista32
 __
 creation the location with a projected dataset (10mpopulatedplaces.shp)
 data
 [http://www.naturalearthdata.com/http//www.naturalearthdata.com/download/10m/cultural/
 10m-populated-places.zip]
 __
 => creation of the location ok
 __
 v.in.ogr dsn=C:\temp\10m_populated_places\10mpopulatedplaces.shp
 output=import
 Die Projektionsinformationen des Eingabedatensatzes und der aktuellen
 Location scheinen übereinzustimmen.
 Layer: 10mpopulatedplaces
 Importiere 6599 Objekte der Karte...
 Building topology for vector map <import>...
 Registering primitives...
    60006599 primitives registered
 6599 vertices registered
 Building areas...
 0 areas built
 0 isles built
 Attaching islands...
 Attaching centroids...
 Number of nodes: 6599
 Number of primitives: 6599
 Number of points: 6599
 Number of lines: 0
 Number of boundaries: 0
 Number of centroids: 0
 Number of areas: 0
 Number of isles: 0
 __
 => import ok
 __
 v.external dsn=C:\temp\10m_populated_places\10mpopulatedplaces.shp
 output=vlinkext
 Data source contains 1 layers:
 10mpopulatedplaces
 __
 g.list type=vect
 vector files available in mapset <data>:
 import
 __
 => link to external not working, because there is no link, but there is
 also no error-message with v.external
 __
 g.gisenv --v
 GISDBASE='C:/gisdata/grassdata';
 LOCATION_NAME='populatedplaces';
 MAPSET='data';
 GRASS_GUI='wxpython';
 DEBUG='3';
 __
 (Mon Jan 18 00:21:23 2010)
 output=vlinkext2
 10mpopulatedplaces
 (Mon Jan 18 00:21:24 2010) Command finished (0 sec)
 __
 g.list type=vect
 import
Ticket URL: <http://trac.osgeo.org/grass/ticket/878>
