[GRASS-dev] Re: [GRASS GIS] #873: r.univar: allow percentile= to be doubles
GRASS GIS trac at osgeo.org
Mon Jan 18 06:09:44 EST 2010
  Reporter:  hamish       |       Owner:  grass-dev at lists.osgeo.org
      Type:  enhancement  |      Status:  new
  Priority:  major        |   Milestone:  6.5.0
 Component:  Raster       |     Version:  svn-develbranch6
Resolution:               |    Keywords:  r.univar, stats
  Platform:  All          |         Cpu:  All
Comment (by mmetz):
 Replying to [comment:1 glynn]:
 > Note that `r.quantile` supports non-integer percentiles, works with
 large maps, and is significantly more efficient.
 IMHO, it would still be nice if `r.univar` supports floating point
 percentiles. The `r.univar` manual could mention that `r.quantile` is the
 better choice if only quantiles and/or percentiles are requested, e.g.
 under NOTES where it already says that `r.univar` can use large amounts of
 system memory for extended statistics. I would suggest to also add
 `r.quantile` to the SEE ALSO section.
 Markus M
Ticket URL: <https://trac.osgeo.org/grass/ticket/873#comment:2>
