[GRASS-dev] [GRASS GIS] #880: Grass 6.5 wxpython location wizard:
UTM zone selector widget is frozen
trac at osgeo.org
Mon Jan 18 19:38:57 EST 2010
#880: Grass 6.5 wxpython location wizard: UTM zone selector widget is frozen
Reporter: epatton | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.5.0
Component: wxGUI | Version: svn-develbranch6
Keywords: location wizard, wxpython, gui | Platform: Linux
Cpu: x86-64 |
Using 6.5 svn compiled from Jan.17th source, Ubuntu Linux 9.10.
The UTM zone selection widget is frozen in the wxpython location selection
wizard.
Steps to reproduce:
1. grass -gui
2. Define new location with Location wizard
3. 'Select coordinate system parameters from list'
4. In search box, choose projection code "UTM".
5. Choose radio button 'Datum with associated ellipsoid'.
6. The default projection zone is 30, but if you click in the box to enter
a new projection zone, the value changes to '1' and cannot be either
deleted with backspace, or incremented with the up/down arrow widget to
the right of the dialog box.
~ Eric
Ticket URL: <http://trac.osgeo.org/grass/ticket/880>
