[GRASS-dev] Building winGRASS: packager.sh on MingW calls MS-VS's
dumpbin tool
Markus Neteler
neteler at osgeo.org
Tue Jan 19 01:52:43 EST 2010
when following
https://trac.osgeo.org/grass/wiki/CompileOnWindows#CompilingandInstallingGRASS6.4.0
(i.e., running ./mswindows/osgeo4w/package.sh with MinGW):
GRASS is compiled, HTML manual is built etc. Then it installs (tar xBf ...),
(man/ is skipped), then "STARTING cleanup", and then
"STARTING building vc libraries"
Then it fails with
mswindows/osgeo4w/mklibs.sh: dumpbin: command not found
I wonder why it tries to use VC stuff here. Is it for the QGIS interface?
If so, what's the trick here? If Visual Studio is needed, shouldn't it be
mentioned in the install instructions?
confused,
Markus
