[GRASS-dev] [GRASS GIS] #883: Building winGRASS: packager.sh on MingW calls MS-VS's dumpbin
GRASS GIS trac at osgeo.org
Tue Jan 19 10:46:54 EST 2010
 Reporter:  hellik       |       Owner:  grass-dev at lists.osgeo.org
     Type:  enhancement  |      Status:  new
 Priority:  normal       |   Milestone:  6.4.0
Component:  Compiling    |     Version:  svn-releasebranch64
 Keywords:               |    Platform:  MSWindows Vista
      Cpu:  x86-32       |
 from the dev-ml
 >Hi,
 >when following
 >https://trac.osgeo.org/grass/wiki/CompileOnWindows#CompilingandInstallingGRASS6.4.0
 >(i.e., running ./mswindows/osgeo4w/package.sh with MinGW):
 >GRASS is compiled, HTML manual is built etc.  Then it installs (tar xBf
 >(man/ is skipped), then "STARTING cleanup", and then
 >"STARTING building vc libraries"
 >Then it fails with
 >mswindows/osgeo4w/mklibs.sh: dumpbin: command not found
 >I wonder why it tries to use VC stuff here. Is it for the QGIS interface?
 >If so, what's the trick here? If Visual Studio is needed, shouldn't it be
 >mentioned in the install instructions?
 >confused,
 >Markus
 this VC stuff is for the QGIS-interface, lines 94-136 should be commented
 out.
 added a patch for grass64-relbranch
 Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/883>
