[GRASS-dev] winGRASS: 'layer manager' window hidden by 'mapdisplay' windows
Michael Barton michael.barton at asu.edu
Tue Jan 19 18:11:45 EST 2010
Do you know which version of Python and wxPython you are using? It sounds like a wxPython bug. But maybe there is something we can do about it.
Michael
______________________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Arizona State University
Tempe, AZ  85287-2402
USA
voice: 	480-965-6262 (SHESC), 480-727-9746 (CSDC)
fax:          480-965-7671(SHESC), 480-727-0709 (CSDC)
www: 	http://csdc.asu.edu, http://shesc.asu.edu
		http://www.public.asu.edu/~cmbarton
On Jan 19, 2010, at 1:16 PM, grass-dev-request at lists.osgeo.org wrote:
> Message: 2
> Date: Tue, 19 Jan 2010 18:44:19 +0100
> From: Jan To?ovsk? <j.tosovsky at tiscali.cz>
> Subject: RE: [GRASS-dev] winGRASS: 'layer manager' window hidden by
> To: <grass-dev at lists.osgeo.org>
> Message-ID: <002a01ca992f$09410850$af8d664e at hanz>
> Content-Type: text/plain;       charset="iso-8859-2"
>>> would it be  possible to invert the stacking order of the 'layer
>>> manager' window
>>> and the 'map display' windows? Currently (XP, current
>> 6.4.SVN), when the wxGUI
>>> opens, the layer manager window is in the background.
>>> To get it to the front requires several attempts in the menu bar (or
>>> repositioning
>>> of the 'map display' windows on the screen).
>>> Markus
>> I've seen this on a couple of students' older laptops and
>> assumed it was an age/laptop related item. The stacking order
>> actually is set as you suggested, and on my Mac, the layer
>> manager always starts on top and in the center; the first map
>> display is to the upper left and under the layer manager.
>> There may be a way to force this even more explicitly, but I
>> don't understand why it is is getting reversed on some XP systems.
> I can also confirm it on my Win XP. I've just been considering to report it
> The most irritating thing is improper activation of the layer manager via
> menu bar, if map display is activated. You must click three times on the bar
> to get the layer manager active. If Windows task bar is clicked for the
> first time, a layer manager can be seen in foreground for a while, but it is
> immediately covered with the map. The second click minimizes the layer
> manager to the bar and third one restores it. In the latter case the layer
> manager finally stays in foreground. If the map is now activated by clicking
> on the menu bar, reactivating of layer manager is Ok. But if the map window
> is activated clicking into the map or window title bar, events are again
> captured somehow (and you need 3 clicks to the menu bar to activate the
> layer manager). So I suspect mainly some map window mouse handlers.
> I've recorder short video, but it is not very clear:
> http://screencast.com/t/NjU1OTQwMD
> Jan
