[GRASS-dev] Re: [GRASS GIS] #878: v.external not working on WinGrass
GRASS GIS trac at osgeo.org
Tue Jan 19 21:05:30 EST 2010
  Reporter:  hellik           |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect           |      Status:  new
  Priority:  normal           |   Milestone:  6.4.0
 Component:  Vector           |     Version:  svn-releasebranch64
Resolution:                   |    Keywords:  v.external, vector, windows
  Platform:  MSWindows Vista  |         Cpu:  x86-32
Changes (by neteler):
  * priority:  critical => normal
Comment:
 Replying to [comment:3 hellik]:
 > Replying to [comment:2 neteler]:
 > > You need to specify also the layer:
 > > v.external dsn=C:\temp\ncdata\exporthospital.shp output=testvexternal
 layer=exporthospital
 > to specify the layer is in the "optional"-tab of the v.external, so
 maybe this option should go into "required"?
 That's unfortunately not possible, since
 v.external help
    layer   OGR layer name. If not given, available layers are printed
 only.
 If you make it a requirement, you can no longer print the layer names.
 I'm afraid that this is "invalid" although I understand the user
 perception.
 Same thing as for r.proj/v.proj etc.
Ticket URL: <http://trac.osgeo.org/grass/ticket/878#comment:4>
