[GRASS-dev] Re: [GRASS GIS] #885: WinGrass: displaying r.external-linked raster data not working
GRASS GIS trac at osgeo.org
Wed Jan 20 00:05:17 EST 2010
  Reporter:  hellik           |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect           |      Status:  new
  Priority:  critical         |   Milestone:  6.4.0
 Component:  Display          |     Version:  svn-releasebranch64
Resolution:                   |    Keywords:  r.external, WinGrass
  Platform:  MSWindows Vista  |         Cpu:  x86-32
Comment (by glynn):
 Replying to [ticket:885 hellik]:
 > fresh Grass64svn, self compiled,
 > nc-sample-dataset
 > elevation exported as gtiff
 > linking by r.external seems to work
 > basic information raster of the linked data is available
 > but if i want to display the linked raster in the wxgui, following error
 message comes up:
 "Error: Unable to locate symbol <GDALAllRegister>
 I suspect that it needs to be e.g. `GDALAllRegister at 0`, as the functions
 use the "stdcall" (aka "pascal") calling convention.
 It works with the version of GDAL I have here (which I built from source),
 which for some reason seems to be using "ccall" (the symbols don't have
 the @<size> suffix).
 You could try using "`make GDAL_DYNAMIC=`" to link libgis directly against
 GDAL, rather than using `LoadLibrary()`.
 To make it work with a stdcall version of GDAL, I need to know the
 decorated names.
 OTOH, it may be better to simply omit the r.external support from 6.5;
 it's very out of date (it was back-ported shortly after the first draft of
 the code was added to 7.0, and hasn't been updated since).
Ticket URL: <http://trac.osgeo.org/grass/ticket/885#comment:1>
