[GRASS-dev] winGRASS compilation: perl not found (needed for MAN)
Glynn Clements
glynn at gclements.plus.com
Wed Jan 20 23:59:48 EST 2010
Markus Neteler wrote:
> >> I have reduced it to these errors here:
> >> htmlmapdriver.html:63
> >> wxGUI.html:154
> >> wxGUI.Vector_Digitizing_Tool.html:210
> > yeah, and https://trac.osgeo.org/grass/ticket/612
> > just one last repeat of the python vs. perl dep:
> Simple suggestion for 6.4: Since the backport of the Python version is
> trivial, why not have both converters in Perl and Python?
> Use Perl as default and, if missing, try the Python version.
I'd suggest the other way around. The Python version can handle
tables, the Perl version can't. That's why I wrote the Python version
in the first place.
