[GRASS-dev] Re: [GRASS GIS] #882: i18n enabled winGRASS: properties dialog not opening
GRASS GIS trac at osgeo.org
Fri Jan 22 05:12:55 EST 2010
  Reporter:  neteler       |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect        |      Status:  new
  Priority:  blocker       |   Milestone:  6.4.0
 Component:  wxGUI         |     Version:  svn-releasebranch64
Resolution:                |    Keywords:
  Platform:  MSWindows XP  |         Cpu:  x86-32
Comment (by glynn):
 Replying to [comment:5 neteler]:
 > On a Japanese Linux box, the current encoding is:
 r.cost --interface-description
 <?xml version="1.0" encoding="EUC-JP"?>
 > but should be UTF8.
 What do you mean by "should be"? Are the descriptions encoded in EUC-JP or
 in UTF-8? First and foremost, the encoding specified in the header must be
 the encoding which is actually used for the data.
 The strings to which `opt->label` and `opt->description` point will be in
 the locale's encoding, as that's how `dgettext()` works, and that's how
 they need to be encoded so that the --help output displays correctly on
 the user's terminal. `G__usage_xml()` doesn't recode the data; it just
 copies the strings into the output.
 If you want the --interface-description output to always use UTF-8, then
 `G__usage_xml()` will need to recode any localised strings with `iconv()`.
 There shouldn't be any problem with encoding=EUC-JP, but encoding=CP932
 may be problematic as "CP932" isn't an IANA-registered encoding (the IANA
 name is "Windows-31J"), so it may not be recognised by XML parsers.
 [http://www.iana.org/assignments/character-sets IANA-registered encodings]
Ticket URL: <http://trac.osgeo.org/grass/ticket/882#comment:7>
