[GRASS-dev] Re: [GRASS GIS] #882: i18n enabled winGRASS: properties dialog not opening
GRASS GIS trac at osgeo.org
Fri Jan 22 23:17:17 EST 2010
  Reporter:  neteler  |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect   |      Status:  new
  Priority:  blocker  |   Milestone:  6.4.0
 Component:  wxGUI    |     Version:  svn-releasebranch64
Resolution:           |    Keywords:  wingrass
  Platform:  All      |         Cpu:  x86-32
Comment (by glynn):
 Replying to [comment:10 neteler]:
 GRASS 6.4.0svn (nc_spm_08):~ > file en.txt ja.txt
 en.txt: ASCII English text
 ja.txt: ISO-8859 English text
 > So: while it advertises EUC-JP, the content appears to be ISO-8859 if I
 got the test right (thanks for hint to Hamish).
 Nah. "file"'s encoding detection is rather rudimentary. If it sees a mix
 of ASCII and 8-bit characters, and it isn't UTF-8, it concludes that it's
 ISO-8859.
 Based upon this I'd say that it's EUC-JP; a Japanese locale on Unix is
 likely to use either UTF-8 or EUC-JP, and file can detect UTF-8. If you
 want a more accurate test, try iconv which each encoding in turn and see
 which one works, or load the file in Firefox and see which encoding it
 selects.
Ticket URL: <http://trac.osgeo.org/grass/ticket/882#comment:11>
