[GRASS-dev] Re: [GRASS GIS] #882: i18n enabled winGRASS: properties dialog not opening
trac at osgeo.org
Sat Jan 23 08:55:07 EST 2010
Reporter: neteler | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: blocker | Milestone: 6.4.0
Component: wxGUI | Version: svn-releasebranch64
Resolution: | Keywords: wingrass
Platform: MSWindows XP | Cpu: x86-32
Comment (by glynn):
Replying to [comment:14 neteler]:
> I see, so it was an improper setting here. So, setting on Linux:
export LANG=ja_JP.UTF-8
export LANGUAGE=ja_JP.UTF-8
export LC_MESSAGES=ja_JP.UTF-8
> enables r.walk to come up with a translated wxGUI. Excellent.
> This reduces the problem to the Windows encoding issue.
Hmm; no. If it doesn't work with LANG=ja_JP, that's a bug.
Did you try the fix suggested in comment:4?
Ticket URL: <http://trac.osgeo.org/grass/ticket/882#comment:15>
