[GRASS-dev] Re: [GRASS GIS] #882: i18n enabled winGRASS: properties dialog not opening
trac at osgeo.org
Sat Jan 23 10:49:27 EST 2010
Reporter: neteler | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: blocker | Milestone: 6.4.0
Component: wxGUI | Version: svn-releasebranch64
Resolution: | Keywords: wingrass
Platform: All | Cpu: x86-32
Comment (by glynn):
Replying to [comment:16 neteler]:
> I have tried (now attached) patch from comment 4, on Linux box.
> In both cases the wxGUI of r.walk comes now up in Japanese.
The more interesting question is whether it works on Windows (I suspect
that `GUI.ParseCommand()` may need similar treatment).
Also, it should probably be using the encoding from the XML header rather
than
`locale.getdefaultlocale()`.
Ticket URL: <http://trac.osgeo.org/grass/ticket/882#comment:17>
