[GRASS-dev] Re: [GRASS GIS] #631: Discrepancies between tcl/tk and
wxpython PROJ_INFO files
trac at osgeo.org
Sat Jan 23 19:25:49 EST 2010
#631: Discrepancies between tcl/tk and wxpython PROJ_INFO files
Reporter: voncasec | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: default | Version: unspecified
Resolution: | Keywords: Projections, wxpython, tcltk
Platform: Unspecified | Cpu: Unspecified
Old description:
> I have been noticing some discrepancies in the PROJ_INFO files that are
> created using Grass6.4 RC4 between the projection values option in the
> tcltk interface and the location wizard option using the wxpython
> interface.
> For example, inputting the projection info:
> Coordinate System=UTM
> Datum=Nad27 - T04 (Transformation Parameters for Alaska)
> Ellipse: Clark66
> Zone=8
> I get the following PROJ_INFO files created.
> tcltk interface results:
> datum: nad27
> nadgrids: alaska
> proj: utm
> ellps: clark66
> a: 6378206.4000000004
> es: 0.0067686580
> f: 294.9786982000
> zone: 8
> wxpython results:
> name: Universe Transverse Mercator
> proj: utm
> ellps: clark66
> zone: 8
> no_defs: defined
> The summary at the end of the wxpython location wizard method says the
> proj.4 definition is:
> +proj=utm, +zone=8, +a= 6378206.4000000004, +rf=294.9786982000, +dx=-22,
> +dy=157.0, +dz=176.0, +no_defs, +nadgrids=alaska
> but if I run g.proj -j -f, I get the following output (which matches the
> PROJ_INFO file):
> +proj=utm +no_defs +zone=8 +a=6378206.4 +rf=294.9786982 +to_meter=1
New description:
interface.
Ellipse: Clark66
Zone=8
datum: nad27
nadgrids: alaska
proj: utm
ellps: clark66
es: 0.0067686580
f: 294.9786982000
zone: 8
wxpython results:
proj: utm
ellps: clark66
zone: 8
no_defs: defined
PROJ_INFO file):
Comment (by neteler):
(prettified original report)
I just wonder if it is a problem what "nad27" isn't in the wxpython
PROJ_INFO file
Ticket URL: <http://trac.osgeo.org/grass/ticket/631#comment:1>
