[GRASS-dev] Re: [GRASS GIS] #489: g.setproj: sets proj info with
missing UTM zone
trac at osgeo.org
Sat Jan 23 19:52:44 EST 2010
#489: g.setproj: sets proj info with missing UTM zone
Reporter: hamish | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: minor | Milestone: 6.4.0
Component: default | Version: 6.4.0 RCs
Resolution: | Keywords: g.setproj
Platform: Linux | Cpu: x86-32
Old description:
> Hi,
> with g.setproj it is possible to set the region so that the resulting
> PROJ_INFO file is missing the zone: field. Perhaps
> this is because 'g.region -p' says the zone is -55 while g.proj
> had 55(S)?
> G640rc2> g.setproj
> Would you still like to change some of the parameters?(y/n) [n] y
> WARNING: Zone in default geographic region definition: -55
> is different from zone in PROJ_INFO file: 55
> Please specify projection name
> >utm
> [ do we want a space after the '>' prompt? ]
> Do you wish to specify a geodetic datum for this location?(y/n) [y] y
> Please specify datum name
> >custom
> [I did want the datum to be Australia GD 1994, but that's not a choice]
> Please specify ellipsoid name
> >grs80
> Please specify datum transformation parameters
> >towgs84=0,0,0
> Parameters to be used are:
> "towgs84=0,0,0"
> Is this correct?(y/n) [y] y
> South Hemisphere(y/n) [n] y
> The UTM zone is now set to 55
> Do you want to change the UTM zone?(y/n) [n] n
> UTM zone information has not been updated
> Projection information has been recorded for this location
> then
> g.proj -p
> -PROJ_INFO-------------------------------------------------
> name : Universe Transverse Mercator
> towgs84 : 0,0,0
> proj : utm
> ellps : grs80
> a : 6378137.0000000000
> es : 0.0066943800
> f : 298.2572221010
> south : defined
> -PROJ_UNITS------------------------------------------------
> unit : meter
> units : meters
> meters : 1.0
> and then r.in.gdal segfaults when attempting the matching proj settings
> comparison. (strcmp() missing key value in lib/gis/make_loc.c)
> Hamish
New description:
had ?
G640rc2> g.setproj
>utm
>custom
>grs80
>towgs84=0,0,0
"towgs84=0,0,0"
then
g.proj -p
towgs84 : 0,0,0
proj : utm
ellps : grs80
es : 0.0066943800
f : 298.2572221010
south : defined
unit : meter
units : meters
meters : 1.0
Hamish
Comment (by neteler):
The code chunk in general/g.setproj/main.c (see
[source:grass/branches/develbranch_6/general/g.setproj/main.c#L413]) is:
if (parm->ask) {
if (G_strcasecmp(desc->type, "bool") == 0) {
if (G_yes((char *)desc->desc, 0)) {
G_set_key_value(desc->key, "defined",
out_proj_keys);
if (G_strcasecmp(parm->name, "SOUTH") == 0)
cellhd.zone = -abs(cellhd.zone);
and in lib/proj/get_proj.c it is (line 154)
/* if zone is negative, write abs(zone) and define south */
info->zone = -info->zone;
So it seems to be valid?
Ticket URL: <http://trac.osgeo.org/grass/ticket/489#comment:1>
