[GRASS-dev] Re: [GRASS GIS] #631: Discrepancies between tcl/tk and wxpython PROJ_INFO files
GRASS GIS trac at osgeo.org
Sun Jan 24 00:06:59 EST 2010
  Reporter:  voncasec     |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect       |      Status:  new
  Priority:  normal       |   Milestone:  6.4.0
 Component:  default      |     Version:  unspecified
Resolution:               |    Keywords:  Projections, wxpython, tcltk
  Platform:  Unspecified  |         Cpu:  Unspecified
Comment (by cmbarton):
 The wxPython GUI has a location wizard. The location wizard uses g.proj to
 create the location and the PROJ_INFO file.
 The TclTk GUI does not have a location wizard. The location was created by
 ????. Maybe by g.projection??? an EPSG code??? Something else??? These may
 well make a different PROJ_INFO file.
 The real question is are the locations different in terms of their
 projection parameters. What happens when you run g.region -gp?
 What you see in the PROJ4 string in the location wizard is the string that
 goes into g.proj. It is based on what you picked.
 A further question, what version of 6.4 are you using (when compiled) and
 for what platform?
 Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/631#comment:2>
