[GRASS-dev] Re: [GRASS GIS] #489: g.setproj: sets proj info with missing UTM zone
GRASS GIS trac at osgeo.org
Sun Jan 24 02:48:47 EST 2010
  Reporter:  hamish   |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect   |      Status:  new
  Priority:  minor    |   Milestone:  6.4.0
 Component:  default  |     Version:  6.4.0 RCs
Resolution:           |    Keywords:  g.setproj
  Platform:  Linux    |         Cpu:  x86-32
Old description:
> Hi,
> with g.setproj it is possible to set the region so that the resulting
> PROJ_INFO file is missing the zone: field. Perhaps
> this is because 'g.region -p' says the zone is -55 while g.proj
> had  ?
> G640rc2> g.setproj
> Would you still like to change some of the parameters?(y/n) [n] y
> WARNING: Zone in default geographic region definition: -55
>          is different from zone in PROJ_INFO file: 55
> Please specify projection name
> >utm
> [ do we want a space after the '>' prompt? ]
> Do you wish to specify a geodetic datum for this location?(y/n) [y] y
> Please specify datum name
> >custom
> [I did want the datum to be Australia GD 1994, but that's not a choice]
> Please specify ellipsoid name
> >grs80
> Please specify datum transformation parameters
> >towgs84=0,0,0
> Parameters to be used are:
> "towgs84=0,0,0"
> Is this correct?(y/n) [y] y
> South Hemisphere(y/n) [n] y
> The UTM zone is now set to 55
> Do you want to change the UTM zone?(y/n) [n] n
> UTM zone information has not been updated
> Projection information has been recorded for this location
> then
>  g.proj -p
> -PROJ_INFO-------------------------------------------------
> name       : Universe Transverse Mercator
> towgs84    : 0,0,0
> proj       : utm
> ellps      : grs80
> a          : 6378137.0000000000
> es         : 0.0066943800
> f          : 298.2572221010
> south      : defined
> -PROJ_UNITS------------------------------------------------
> unit       : meter
> units      : meters
> meters     : 1.0
> and then r.in.gdal segfaults when attempting the matching proj settings
> comparison. (strcmp() missing key value in lib/gis/make_loc.c)
> Hamish
New description:
 had 55(S)?
 G640rc2> g.setproj
 >utm
 >custom
 >grs80
 >towgs84=0,0,0
 "towgs84=0,0,0"
 then
  g.proj -p
 towgs84    : 0,0,0
 proj       : utm
 ellps      : grs80
 es         : 0.0066943800
 f          : 298.2572221010
 south      : defined
 unit       : meter
 units      : meters
 meters     : 1.0
 Hamish
Comment (by hamish):
 [undid "55(S)" edit in description; a while back I filed an upstream trac
 wish to have the orig. desc. box minimized by default to avoid accidental
 edits, it got some attention]
 the problem is not that the UTM zone's pos/neg sign comes out wrong, the
 problem is that the zone: term is not written at all!
 Hamish
 ps- in linking to source code via trac if you skip giving a rev number you
 still need to use @, e.g.:
  source:grass/branches/develbranch_6/general/g.setproj/main.c@#L413
Ticket URL: <http://trac.osgeo.org/grass/ticket/489#comment:2>
