[GRASS-dev] Re: [GRASS GIS] #555: v.in.gpsbabel on wingrass: g.proj
error
trac at osgeo.org
Sun Jan 24 08:41:29 EST 2010
#555: v.in.gpsbabel on wingrass: g.proj error
Reporter: hamish | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: minor | Milestone: 6.4.0
Component: Vector | Version: 6.4.0 RCs
Resolution: | Keywords: wingrass, v.in.gpsbabel, g.proj
Platform: MSWindows XP | Cpu: x86-32
Comment (by hamish):
Replying to [comment:4 hamish]:
> Still breaks with -f removed. $? is "5".
apparently exit code 5 is "ERROR_ACCESS_DENIED".
http://msdn.microsoft.com/en-us/library/ms681382(VS.85).aspx
It could be for the PROJ_INFO file, but as the program works fine from the
command line I'm not sure what to make it.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/555#comment:5>
