[GRASS-dev] Re: [GRASS GIS] #888: Error in i.ortho.photo
trac at osgeo.org
Mon Jan 25 13:39:36 EST 2010
Reporter: nikosdu1980 | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: wxGUI | Version: unspecified
Resolution: | Keywords: i.ortho.photo
Platform: Linux | Cpu: Unspecified
Comment (by glynn):
Replying to [comment:5 hamish]:
> somehow in the wxPython code the "wait" variable is becoming a list on
your system. That doesn't happen for me and I don't see any obvious reason
for it in the code. A more expert wxPy'er than myself would need to tell
you why and how to fix it.
OnXTerm() is seriously broken, and should be re-written or removed.
E.g.:
# run the command
command = ' '.join(command)
and:
cmdlist = [xtermwrapper, '-e "%s"' % grassrun, command]
Hint: xterm's "-e" switch doesn't take an argument. It indicates that all
remaining arguments are the program and its arguments (i.e. the next
argument after -e is the program, the one after that is argv[1], etc).
This also applies to the grass-xterm-wrapper and grass-run scripts: they
take individual arguments, not a "command string".
Ticket URL: <http://trac.osgeo.org/grass/ticket/888#comment:7>
