[GRASS-dev] Re: [GRASS GIS] #891: add a command g.move
GRASS GIS trac at osgeo.org
Mon Jan 25 19:55:56 EST 2010
  Reporter:  timmie       |       Owner:  grass-dev at lists.osgeo.org
      Type:  enhancement  |      Status:  new
  Priority:  normal       |   Milestone:  6.4.0
 Component:  default      |     Version:  unspecified
Resolution:               |    Keywords:
  Platform:  Unspecified  |         Cpu:  Unspecified
Changes (by hamish):
  * type:  defect => enhancement
Comment:
 (for the most part) the multi-user access rules mean that within a certain
 grass session you are only allowed to write to the current mapset. you can
 pull maps in, but you can't push them out.
 so the method is:
 g.copy map at othermapset,map
 then change to the other mapset and remove maps as needed.
 the exception is i.rectify.
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/891#comment:1>
