[GRASS-dev] Re: [GRASS GIS] #827: standalone-installer: execution
failed on g.proj.exe -p
trac at osgeo.org
Mon Jan 25 20:31:25 EST 2010
#827: standalone-installer: execution failed on g.proj.exe -p
Reporter: timmie | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: Installation | Version: svn-releasebranch64
Resolution: | Keywords: wingrass
Platform: MSWindows XP | Cpu: x86-32
Comment (by hamish):
can you run "g.proj -p" from the GRASS> terminal command line when
starting GRASS in text mode, without any GUI? what error do you get? if
you run "echo $?" directly after it dies what does that say?
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/827#comment:18>
