[GRASS-dev] Re: [GRASS GIS] #693: wxGUI menus: i.ortho.photo locks
up GUI
trac at osgeo.org
Mon Jan 25 23:04:24 EST 2010
#693: wxGUI menus: i.ortho.photo locks up GUI
Reporter: hamish | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: wxGUI | Version: svn-develbranch6
Resolution: | Keywords: i.ortho.photo
Platform: All | Cpu: x86-64
Comment (by kyngchaos):
The only problem I see is in Leopard+, with the X11 autostart. If X11
isn't running yet when you start r.digit or i.ortho.photo, and you type
the raster/group name in the Terminal before the monitor window opens (as
it waits for X11 to start), it will complain about having no display. If
you wait for the monitor display to open before continuing in the
Terminal, it's fine except that the monitor window opens in front of the
Terminal because X11 runs in the foregrond instead of the background.
Did that make sense? ;)
I suppose I could force X11 to run on GRASS startup like in earlier
versions of the system, but defeats the purpose (and convience) of the X11
autostart.
Ticket URL: <https://trac.osgeo.org/grass/ticket/693#comment:38>
