[GRASS-dev] wingrass msys term prompt cosmetics
Markus Neteler
neteler at osgeo.org
Tue Jan 26 08:44:50 EST 2010
On Tue, Jan 26, 2010 at 7:48 AM, Hamish <hamish_b at yahoo.com> wrote:
>> Hamish wrote:
>> > that's ~ 62 chars on a 80 char wide window!
> Markus:
>> Perhaps
>> PS1='GRASS640> '
> is the idea to remind the user what they are using (instead
> of bug reports just saying "I'm using GRASS 6"), or to
> de-confuse those with multiple versions as the command set
> might be a bit different? (I expect that has a developer bias,
> end users will typically only run one version at a time)
I would say: both.
> I don't really object to anything less than ~15 char long,
> I'm just trying to land on the most intuitive solution.
> another idea:
> GRASS 6.4>
Perfect.
Markus
