[GRASS-dev] Re: [GRASS GIS] #693: wxGUI menus: i.ortho.photo locks up GUI
GRASS GIS trac at osgeo.org
Tue Jan 26 20:13:05 EST 2010
  Reporter:  hamish  |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect  |      Status:  new
  Priority:  major   |   Milestone:  6.4.0
 Component:  wxGUI   |     Version:  svn-develbranch6
Resolution:          |    Keywords:  i.ortho.photo
  Platform:  All     |         Cpu:  x86-64
Comment (by hamish):
 Replying to [comment:38 kyngchaos]:
 > The only problem I see is in Leopard+, with the X11 autostart.
 > If X11 isn't running yet when you start r.digit or i.ortho.photo,
 > and you type the raster/group name in the Terminal before the
 > monitor window opens (as it waits for X11 to start),
 i.e. you get a Terminal.app (instant) not an xterm (waits for X11) for the
 echo "================================================================="
 echo "If you wish to resize the X monitor, do so now. Window size is"
 echo "locked while interactive modules are running."
 part?
 > it will complain about having no display.  If you wait for the
 > monitor display to open before continuing in the Terminal, it's
 > fine
 perhaps add this to the above script:
 if [ "`uname`" = "Darwin" ] ; then
    echo "Please wait a moment for X11 to start and a monitor to open."
 fi
 > except that the monitor window opens in front of the Terminal
 > because X11 runs in the foregrond instead of the background.
 I think that's minor enough and these modules are used infrequently enough
 that we can just ignore it and let folks move windows out of the way
 themselves.
 > Did that make sense? ;)
 sure
 > I suppose I could force X11 to run on GRASS startup like in
 > earlier versions of the system, but defeats the purpose (and
 > convience) of the X11 autostart.
 IMO these are used infrequently enough that the computer's resources would
 be put do better use doing other things.
 Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/693#comment:39>
