Fwd: [GRASS-dev] Scripting in Linux
Markus Neteler
neteler at osgeo.org
Wed Jan 27 18:18:31 EST 2010
On Wed, Jan 27, 2010 at 6:47 PM, Glynn Clements
<glynn at gclements.plus.com> wrote:
> In 6.4, there is (or was?)
Was. It has been solved 25 Jan 2010 in SVN.
> a known bug with the GUI and non-UTF-8
> locales: the GUI converts the text from the locale's encoding to
> UTF-8, but leaves the original encoding in the XML header, which can
> confuse the XML parser. But this depends upon the locale's encoding,
> not the encoding of the .po file.
Please update to latest 6.4.svn from SVN if not done already to exclude
that you locally have the already solved bug.
Markus
