[GRASS-dev] Re: [GRASS GIS] #714: spawn.c differences between 6.4
and 6.5
trac at osgeo.org
Thu Jan 28 08:56:59 EST 2010
#714: spawn.c differences between 6.4 and 6.5
Reporter: neteler | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: reopened
Priority: critical | Milestone: 6.4.0
Component: default | Version: 6.4.0 RCs
Resolution: | Keywords:
Platform: MSWindows XP | Cpu: Unspecified
Comment (by glynn):
Replying to [comment:16 neteler]:
> I assume that this is also needed.
Only for Gentoo, AFAIK, but it won't harm elsewhere (most programs don't
care about `argv[0]`).
If you run a script via the shell (manually or with system()), `argv[0]`
is set to the interpreter (normally to the exact path following the #!,
although in the case of the "`#!/usr/bin/env python`" trick, `argv[0]`
will be just "python").
So the updated version simulates "normal" execution.
Ticket URL: <https://trac.osgeo.org/grass/ticket/714#comment:17>
