[GRASS-dev] Scripting in Linux
Kim Besson
kimbesson1981 at gmail.com
Fri Jan 29 07:13:06 EST 2010
Ok I added to my grass64 file (that includes definition and export of
GISBASE and execution of exec "$GISBASE/etc/Init.sh" "$@")
But Now I'm having a strange problem because it's not being accepted by
g.parser. Instead of opening the Form, with input and output bars,
description and tabs it gives an error and it prints the required data to
run. It seems that I can only run by command line.
Was this expected?
Thank you Hamish for your help
Best regards
Kim
2010/1/29 Hamish <hamish_b at yahoo.com>
> Kim wrote:
> > Regarding your comment related with GRASS_ADDON_PATH
> > environment
> > variable:THis is the only thing in the GRASS
> > Vatriables help:http://grass.itc.it/gdp/html_grass64/grass6.html
> > This environment variable
> > allows the user to extend the GRASS program search paths to
> > include locally developed/installed addon modules which are
> > not distributed with the standard GRASS release.
> > GRASS_ADDON_PATH=/usr/mytools
> > GRASS_ADDON_PATH=/usr/mytools:/usr/local/othertools
> > If I add to the Init.sh for instance
> > GRASS_ADDON_PATH=usr/local/additionalIs this the
> > procedure? (I'm getting some Permission denied
> > error)
> No, don't put it in Init.sh.
> This is what I put in ~/.bashrc
> export GRASS_ADDON_PATH=/usr/src/grass/addons
> Hamish
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20100129/f27a915b/attachment-0001.html
