[GRASS-dev] Re: [GRASS GIS] #898: WinGrass: r.out.xyz error
trac at osgeo.org
Sat Jan 30 18:18:50 EST 2010
Reporter: hellik | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: Raster | Version: svn-releasebranch64
Resolution: | Keywords: wingrass, raster, path
Platform: MSWindows Vista | Cpu: x86-32
Comment (by glynn):
Replying to [ticket:898 hellik]:
> self-compild WinGrass r40741 in osgeo4w-stack
r.out.xyz --verbose input=elevation at PERMANENT output=C:\wd\mg\elev.xyz
Are you running this via the MSys shell or via cmd.exe?
The MSys shell interprets backslashes, so they need to be escaped:
r.out.xyz --verbose input=elevation at PERMANENT output=C:\\wd\\mg\\elev.xyz
or quoted:
r.out.xyz --verbose input=elevation at PERMANENT output='C:\wd\mg\elev.xyz'
In most situations, you can use a forward slash instead:
r.out.xyz --verbose input=elevation at PERMANENT output=C:/wd/mg/elev.xyz
OTOH, if you're running the command via cmd.exe (Windows' own command
prompt), this would be a bug.
Ticket URL: <https://trac.osgeo.org/grass/ticket/898#comment:1>
