[GRASS-dev] Re: [GRASS GIS] #898: WinGrass: r.out.xyz error
trac at osgeo.org
Sat Jan 30 18:51:59 EST 2010
Reporter: hellik | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: Raster | Version: svn-releasebranch64
Resolution: | Keywords: wingrass, raster, path
Platform: MSWindows Vista | Cpu: x86-32
Comment (by hamish):
Does this command work: (from the MSys terminal prompt)
r.stats -1gn elevation > C:\wd\mg\elev.xyz
also, I seem to recall that MS Windows generally prefers you use "double"
quotes for quoting. (for msys it shouldn't matter, but for a DOS-in-a-box
it could)
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/898#comment:3>
