[GRASS-dev] Re: [GRASS GIS] #759: r.patch non-functional in WinGRASS 6.4 svn on Vista
GRASS GIS trac at osgeo.org
Sat Jan 30 22:52:48 EST 2010
  Reporter:  cmbarton         |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect           |      Status:  new
  Priority:  critical         |   Milestone:  6.4.0
 Component:  Raster           |     Version:  6.4.0 RCs
Resolution:                   |    Keywords:  r.patch, wingrass
  Platform:  MSWindows Vista  |         Cpu:  Unspecified
Comment (by glynn):
 Replying to [comment:19 hellik]:
 > so the question will be how this could be implemented in the grass-
 compile- and build process?
 How about adding something like the following to the "default" target in
 the top-level Makefile:
 ifneq ($(strip $(MINGW)),)
         find $(ARCH_DISTDIR) -type f -name '*.exe' | \
         while read file ; do \
             cmd=`basename "$$file" .exe` \
             sed "s/@CMD@/$$cmd/" generic.manifest > "$$file".manifest ; \
         done
 endif
 For 7.0, I'd use a pattern rule for "%.exe.manifest" to build a manifest
 alongside any exe.
 It wouldn't be hard to allow the <description> field to be customised, but
 I'm not sure that really matters. The main thing is to shut UAC up.
Ticket URL: <https://trac.osgeo.org/grass/ticket/759#comment:22>
