[GRASS-dev] Re: [GRASS GIS] #800: r.random and r.reclass - buffer
overflow on long mapset/map names
trac at osgeo.org
Thu Jul 1 08:07:13 EDT 2010
#800: r.random and r.reclass - buffer overflow on long mapset/map names
Reporter: ferrouswheel | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.5.0
Component: Raster | Version: svn-develbranch6
Keywords: | Platform: All
Cpu: All |
Comment(by glynn):
Replying to [comment:6 neteler]:
> > snprintf() isn't in C89; if you want to use it, you need to add a
configure check, and provide an alternate in case it isn't available.
> We do have G_snprintf() in lib/gis/snprintf.c which is a "private"
implementation.
> Should that be used instead?
Yes. Although vsnprintf() isn't guaranteed to exist, so far no-one has
complained about GRASS failing to build, which suggests that platforms
lacking vsnprintf() are uncommon.
Ticket URL: <http://trac.osgeo.org/grass/ticket/800#comment:7>
