[GRASS-dev] can not start grass82
Markus Neteler neteler at osgeo.org
Fri Jul 2 09:13:34 EDT 2010
On Fri, Jul 2, 2010 at 11:08 AM, fire jotawski <jotawski at gmail.com> wrote:
> On Sat, Jun 26, 2010 at 3:53 AM, Martin Landa <landa.martin at gmail.com>
> wrote:
>> 2010/6/25 fire jotawski <jotawski at gmail.com>:
>> > i am using freebsd 8.0 and install grass62.  when i start using grass by
>> > grass62, i got this error message
> many thanks indeed.  i have just realized now that only root can run grass62
> and entering graphic mode without that errors which is not quite right.  i
> need to su to root and run grass62.
This is unusual and not desired. Perhaps a permission problem of the
executable flags?
Markus
