[GRASS-dev] build error in wxpython (grass6_devel)
Massimo Di Stefano massimodisasha at gmail.com
Sun Jul 4 19:45:04 EDT 2010
Hi Markus,
> svn status gui/wxpython/gui_modules/
give me no outputs.
i tried to rebuild all the code doing :
cd /usr/local/src/gis/grass6_devel/
make distclean
rm -rf gui/
svn up
./configure ...
make
but the error persists :
make[1]: `/usr/local/src/gis/grass6_devel/dist.x86_64-unknown-linux-gnu/etc/wxpython/gui_modules/nviz_mapdisp.pyc' is up to date.
make[1]: `/usr/local/src/gis/grass6_devel/dist.x86_64-unknown-linux-gnu/etc/wxpython/gui_modules/nviz_preferences.pyc' is up to date.
make[1]: `/usr/local/src/gis/grass6_devel/dist.x86_64-unknown-linux-gnu/etc/wxpython/gui_modules/nviz.pyc' is up to date.
python -m py_compile /usr/local/src/gis/grass6_devel/dist.x86_64-unknown-linux-gnu/etc/wxpython/gui_modules/nviz_tools.py
SyntaxError: ('invalid syntax', ('/usr/local/src/gis/grass6_devel/dist.x86_64-unknown-linux-gnu/etc/wxpython/gui_modules/nviz_tools.py', 2860, 2, '<<<<<<< .working\n'))
make[1]: *** [/usr/local/src/gis/grass6_devel/dist.x86_64-unknown-linux-gnu/etc/wxpython/gui_modules/nviz_tools.pyc] Error 1
make[1]: Leaving directory `/usr/local/src/gis/grass6_devel/gui/wxpython'
make: *** [install_scripts] Error 2
i opened the file
it show me at line 2860   :   "<<<<<<< .working"
i deleted this line, then going ahead in the build process i got this log :
>> http://www.geofemengineering.it/data/log2.txt
Massimo.
Il giorno 04/lug/2010, alle ore 22.54, Markus Neteler ha scritto:
> On Sun, Jul 4, 2010 at 10:43 PM, Massimo Di Stefano
> <massimodisasha at gmail.com> wrote:
>> Hi All
>> tring to upgrade grass i had a build error on both osx and linux (debian)
>> this the build log from the debian machine running make in the wxpython directory :
>> http://www.geofemengineering.it/data/grass_build_log.txt
>>  i it acommon problem or something goes wrong on my system ?
>> hope the log can help a bit.
> Yes:
> says that you have a patch error (guess you have local changes and
> SVN didn't merge in properly updates from the server)
> Try
> to see what's going on there.
> Markus
