[GRASS-dev] build error in wxpython (grass6_devel)
Massimo Di Stefano
massimodisasha at gmail.com
Mon Jul 5 03:38:52 EDT 2010
Markus,
i don't know why this happens .. but it's weird
i already did :
> rm -rf gui/wxpython/gui_modules/
> svn up gui/wxpython
now i'm doing a new grass checkout from svn in a new devel directory.
tring to reconfigure and rebuild it.
i'm on debian sid derived distro (sidux)
using this configure instruction :
./configure
--with-tcltk-includes=/usr/include/tcl8.5/ \
--with-readline \
--with-sqlite \
--with-postgres \
--with-postgres-includes=/usr/include/postgresql/ \
--with-python \
--with-wxwidgets=/usr/bin/wx-config \
--with-odbc \
--with-geos \
--with-freetype \
--with-freetype-includes=/usr/include/freetype2/ \
--with-cxx \
--with-blas \
--with-lapack \
--with-cairo \
--with-ffmpeg \
--with-ffmpeg-includes="/usr/local/include/libavformat/ /usr/local/include/libavcodec/ /usr/local/include/libavdevice/ /usr/local/include/libavutil/ /usr/local/include/libswscale/" \
--with-glw \
--with-motif \
--enable-largefile \
--enable-64bit
but again, a new checkout don't fix the problem,
opening the file :
gui_modules/nviz_tools.py
i deleted the "<<<<<<< .working'" part, then hit mke again, the build go ahead
bu ends with error :
make[2]: *** [OBJ.x86_64-unknown-linux-gnu/_grass6_wxnviz.so] Error 1
make[2]: Leaving directory `/usr/local/src/gis/grass65_devel/gui/wxpython/nviz'
make[1]: Leaving directory `/usr/local/src/gis/grass65_devel/gui/wxpython'
this erro is the same as in the previouse mail,the log is :
http://www.geofemengineering.it/data/log2.txt
thanks to investigate on that,
i can try to build on osx too, to see if the error can be replicated.
Il giorno 05/lug/2010, alle ore 08.34, Markus Neteler ha scritto:
> hi Massimo,
> On Mon, Jul 5, 2010 at 1:45 AM, Massimo Di Stefano
> <massimodisasha at gmail.com> wrote:
>> Hi Markus,
>>> svn status gui/wxpython/gui_modules/
> and
> svn diff gui/wxpython/gui_modules/
> In the worst caee, if you don't have own changes there
> svn up gui/wxpython
>> SyntaxError: ('invalid syntax', ('/usr/local/src/gis/grass6_devel/dist.x86_64-unknown-linux-gnu/etc/wxpython/gui_modules/nviz_tools.py', 2860, 2, '<<<<<<< .working\n'))
> apparently there is cruft in that file at your end.
> Markus
