[GRASS-dev] build error in wxpython (grass6_devel)
Massimo Di Stefano massimodisasha at gmail.com
Mon Jul 5 04:52:43 EDT 2010
Thanks to All :-)
wxpython build fine.
the error is only on nviz,
i attached a log just to report it (maybe usefull to debug),
i don't need nviz right now,
http://www.geofemengineering.it/data/grass_nviz_build_log.txt
i know there are a lot of work in progress in the nviz code,
thanks Martin!!!! and All Dev team of course ;-)
Il giorno 05/lug/2010, alle ore 10.32, Hamish ha scritto:
> Massimo wrote:
>> I tried on mac osx right now,
>> the build ends with the same error on mac too :
>> SyntaxError: ('invalid syntax',
>> ('/Users/Shared/source/grass6_devel/dist.i386-apple-darwin10.4.0/etc/wxpython/gui_modules/nviz_tools.py',
>> 2860, 2, '<<<<<<< .working\n'))
>> make[1]: ***
>> [/Users/Shared/source/grass6_devel/dist.i386-apple-darwin10.4.0/etc/wxpython/gui_modules/nviz_tools.pyc]
>> Error 1
>> make: *** [install_scripts] Error 2
>> MacBook-Pro-15-di-Massimo-Di-Stefano:wxpython sasha$
> the cruft was in the svn repo. removed in r42703.
> it happens. try again :)
> Hamish
