[GRASS-dev] 6.4.0 blocker bugs
Glynn Clements
glynn at gclements.plus.com
Tue Jul 6 11:00:21 EDT 2010
Helena Mitasova wrote:
> >> I learned that we should await the ctypes port to get rid of SWIG?
> > SWIG is only used within GRASS for the wxGUI vdigit and nviz modules.
> > It's also used to generate wrappers for programmers who wish to access
> > the libraries directly, but these aren't used by any part of GRASS.
> > I suggest disabling all of this in the final release. The vdigit and
> > nviz modules don't work on Windows, and aren't particularly robust on
> > other platforms (and being loaded in-process means that any problems
> > affect the GUI as a whole, not just the vdigit/nviz modules).
> Glynn,
> I assume you are talking about wxnviz here, not the TclTk based nviz
> which runs on windows just fine?
Correct.
