[GRASS-dev] Re: [GRASS GIS] #827: standalone-installer: execution
failed on g.proj.exe -p
trac at osgeo.org
Tue Jul 6 12:28:21 EDT 2010
#827: standalone-installer: execution failed on g.proj.exe -p
Reporter: timmie | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: Installation | Version: svn-releasebranch64
Keywords: wingrass | Platform: MSWindows XP
Cpu: x86-32 |
Comment(by mmetz):
Replying to [comment:21 glynn]:
> The obvious common factor between g.region and g.proj is GDAL.
> I would guess that the libtiff.dll which is being loaded isn't the one
which GDAL wants. You can use [http://www.dependencywalker.com/ Dependency
Walker] to determine where libraries are being loaded from.
> The %PATH% environment variable is the last resort for locating
libraries, so if there is a libtiff.dll in e.g. Windows or
Windows/System32, it will take precedence. The only locations which are
ahead of the Windows directories are the executable's directory (i.e.
$GISBASE/bin) and any "Side-by-Side Assemblies" specified in the program's
manifest (if it has one).
Exactly the same error occurred on one of the systems I maintained last
week, the culprit was a (very old) Windows/System32/libtiff.dll.
Workaround was to move this libtiff.dll to a sandbox place, only then gdal
(and consequently everything using gdal) used the correct libtiff.dll. No
idea what application installed Windows/System32/libtiff.dll. Not sure if
a manifest for g.proj or g.region would work because gdalinfo itself did
not work, same error as shown in the attached pics.
Not a solution but because this affects everything in osgeo4w that uses
gdal I would say this should not keep us from releasing 6.4.0final.
My2c,
Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/827#comment:27>
