[GRASS-dev] GRASS 7 - r3.in.ascii not compiling on Mac
Glynn Clements
glynn at gclements.plus.com
Fri Jul 9 14:16:40 EDT 2010
Barton Michael wrote:
> I just updated from trunk today and tried to compile GRASS 7.
> r3.in.ascii failed to compile with the following error.
> Michael
> cmb-MBP:r3.in.ascii cmbarton$ make
> : && gcc -L/Users/cmbarton/grass_dev/grass70_dev/dist.i386-apple-darwin10.4.0/lib -L/Users/cmbarton/grass_dev/grass70_dev/dist.i386-apple-darwin10.4.0/lib -arch i386 -arch x86_64 -o /Users/cmbarton/grass_dev/grass70_dev/dist.i386-apple-darwin10.4.0/bin/r3.in.ascii OBJ.i386-apple-darwin10.4.0/main.o -lgrass_g3d.7.0.svn -lgrass_gis.7.0.svn
> Undefined symbols for architecture i386:
> "_Rast_set_history", referenced from:
> _main in main.o
This should be fixed by r42746; also for r3.info.
There shouldn't be any other modules with this issue. r3.to.rast is
the only other raster3d module which uses the history functions, and
that already linked against $(RASTERLIB). Any non-raster3d modules
which use the history will have needed to link against $(RASTERLIB) in
order to read/write the history file (G3d has its own versions of
these functions).
This didn't show up on Linux as libgrass_raster is pulled in
automatically by libgrass_g3d, and that's good enough for the GNU
linker. I suspect that it might also have been an issue on Windows.
