[GRASS-dev] Re: [GRASS GIS] #1006: r.terraflow fails to stat()
stream file on Windows
trac at osgeo.org
Fri Jul 9 20:09:00 EDT 2010
#1006: r.terraflow fails to stat() stream file on Windows
Reporter: marisn | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 6.4.0
Component: Raster | Version: svn-releasebranch64
Keywords: wingrass, r.terraflow | Platform: MSWindows Vista
Cpu: x86-32 |
Comment(by hamish):
Replying to [comment:43 mmetz]:
> Hmm. Good to hear that it works on CLI. In wxGUI, it might become
> better once the debug messages have been removed, I had to clear
> output regularly to get it going again. Too much for the wxGUI
> output window?
probably. You'll get similar GUI lockup failures if you try and run vector
modules while DEBUG=5. It can't handle the incoming message volume. Tcl/Tk
had the same problem.
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/1006#comment:45>
