[GRASS-dev] Re: [GRASS GIS] #1106: r.terraflow limited to 32bit
temp files in WinGrass
trac at osgeo.org
Mon Jul 12 03:08:51 EDT 2010
#1106: r.terraflow limited to 32bit temp files in WinGrass
Reporter: hamish | Owner: grass-dev@…
Type: task | Status: new
Priority: normal | Milestone: 6.4.1
Component: Raster | Version: svn-develbranch6
Keywords: wingrass, r.terraflow | Platform: MSWindows XP
Cpu: x86-32 |
Comment(by mmetz):
Replying to [ticket:1106 hamish]:
> The ftell() solution is not 64bit safe though, so it awaits a backport
of G_ftell() [or even better `off_t G_filesize()`] in some later release.
AFAICT this will only work if LFS is globally enabled/disabled in grass,
as in grass7. The modifications done in grass7 are probably too
fundamental to backport (not sure about libgis and the raster part, but
for the vector part I had to change core functions in the vector libs).
BTW, the 2GB temp file limit also applies to various other modules (all
vector modules, r.watershed.seg, r.cost, r.walk, r.drain, r.proj...)
Markus M
Ticket URL: <https://trac.osgeo.org/grass/ticket/1106#comment:2>
